Can anyone point me to memos on configuring the UV2 build process to invoke a third party [yacc(1) style] tool. Hopefully the solution one that fits into the dependency support. Otherwise, support for pre-build commands will suffice.
And I suspect you are correct and one can likely invoke a complex external process. I'm just not so sure about uV2 dealing with dependencies on the files generated by that external process. But it may not be a big deal for you in the end.
See: http://www.keil.com/support/docs/1878.htm
