Problems with MON51 + RTX Tiny
Hallo all,
I'm using Mon51 on my target CPU (80C517) and it works very well, but if my program uses RTX Tiny, sometimes the program hangs after executing some instructions (Single Step or by Setting Breakpoints).
Can somebody help me?
Eugen
  • Eugen;
    I suggest that you contact Keil Tech Support. I had a similar problem with RTX51 Full and Mon51. Tech support was able to get me going but the solution is above MY explanation in this forum. They may have built a knowledge base artical on the solution. I haven't searched.
    Bradford
