Hello, I'm using uVision2 2.40a tool with a Cypress FX2LP cpu. Inside my project I've a global declaration of a 256 byte buffer but when I try to using it something happen and the cpu often hangs like this buffer overlaps other memory area. The code is like the following:
BYTE xdata I2CBuff[256]; . . . for(i=0; i<256; i++) I2CBuff[i] = 0x00; //the upper line hangs!!
to the best of my recollection the Cypress chips do not have a whole lot of XDATA. Are you sure you use no more than there is? look in the M51 file
Here's my guess: i is an 8-bit variable. Now you sit down and think what that would do to your for() loop.
This is the summary of M51:
Program Size: data=56.7 xdata=4543 code=3820 LINK/LOCATE RUN COMPLETE. 0 WARNING(S), 0 ERROR(S)
Here's my guess: i is an 8-bit variable. Great guess Ever so often one can not see the forest for the trees. Erik
You're right ;-) but the cpu hangs also if i<70 (any value a little bigger than 64 will do ...)
OK, next thing to check: watchdog timers and other things that depend on timing of code. Run your program in the simulator and: 1) check if the problem also occurs there 2) if it does, inspect exactly what happens, machine instruction by instruction
No way ... I'm currently using the fifo buffer of USB interface (the chip is a usb2.0 front-end) to store my data ... dirty but funcioning ...
