Can't communicate with 8051 through RS-232
My Problem is that uVision always shows monitor 51 not connected.
I'm using keil c51 7.50 and uvision 3.05c. I want to use RS-232 interface communication with ATMEL "AT89S53"
1.
In the "option for target" window of Keil. I have following setting:
Target
Atmel AT89S53.
Memory Model: compact: variables in PDATA;
Code Rom Size: Compact: 2K functions, 64k programs.
Operation system:RTX-51 full.
Debug
Use: Keil Monitor-51 Driver
Port:COM 1
RTS:Active
Baudrate: 19200
DTR: Active.
Choose cache options for DATA, XDATA, IDATA, CODE.
choose serial interrupt.
Choose Load Application at Startup.
Choose Breakpoints, Watchpoints, Memory Display, Toolbox.
However, in the Monitor-51 Identification, it always says" Monitor-51 not connected"
2.
The 8051 board i use is "MINI-MAX/51-C MICROCONTROL BOARD," made by BiPOM Electronics.
The 8051 chip is "ATMEL 89S53."
The spec is:
1.12K In-System Programmable Flash Memory.
2.256 bytes of RAM.
3.Nine bytes of RAM.
4.Three 16 bit Timer/ Counters
5.Programmable UART Serial Channel.
6.SPI Serial Interface.
7.Programmable Watchdog Timer.
8.32 general purpose I/O pins
3.
I have tried Micro-IDE software made by BiPOM, it can communicate with this board through RS-232 very well. Therefore, it seems the communiocation problem occurs in the Keil Software itself.
I really don't know what is going wrong, and this is my first time using 8051 system.
Could anybody help me?
RAY
