When following the instructions in application note 173, about using the SampTarg project, I built the project and at link it says it cannot find nafxcwd.lib. It can't find it because it doesn't exist. Help please.
I found a fix to this, which is to go: Project->Settings Gerneal Tab -> Microsoft Foundation Classes = "Use MFC in a shared DLL". Then I hit a second problem, When running uv2, when I select SampAtrg in the "Options for Target->Debug" it causes an assertion. Help?
