I have tried to globally disable interrupts using the assembly defines mentioned in the Keil note about nested interrupts. http://www.keil.com/support/docs/2910.htm When I try to call IENABLE or IDISABLE I get assembler errors associated with the MRS LR op-code. Has anyone gotten this to work? Is there an alternative method to globally diasabling interrupts in the Keil environment? Rich
I found the problem. There is an SPI register defined as SPSR (LPC210x.h) which is the same as the Saved Program Staus Register in the ARM core. This creates a conflict when embedding assembly code in C code. Keil, are you listening? ;-) Rich
In the LPX210x.H file that I have the SPI SPSR register is defined as follows:
/* SPI (Serial Peripheral Interface) */ #define SPI_SPCR (*((volatile unsigned char *) 0xE0020000)) #define SPI_SPSR (*((volatile unsigned char *) 0xE0020004)) #define SPI_SPDR (*((volatile unsigned char *) 0xE0020008)) #define SPI_SPCCR (*((volatile unsigned char *) 0xE002000C)) #define SPI_SPTCR (*((volatile unsigned char *) 0xE0020010)) #define SPI_SPTSR (*((volatile unsigned char *) 0xE0020014)) #define SPI_SPTOR (*((volatile unsigned char *) 0xE0020018)) #define SPI_SPINT (*((volatile unsigned char *) 0xE002001C))
Hi Jon, Yes, in mine (I have downloaded the latest update and our package is only a week old) the SPI_ is missing for all SPI SFRs. Richard
The SPI_ prefix has been taken out by Philips. Now we have got this conflict. I am in contact with Philips to sort it out and make it consistent with the datasheets. Reinhard
