bad cpu/memory?
Hello everyone, this time I doubt the problem is caused by my (lack of) c skills, as the issue occurs inside the standard keil STARTUP.A51 file :)
Have a look at this assembly code;
I expanded it to be more "granular", so as to see exactly which partial instruction is failing:
IF IDATALEN <> 0
MOV R0,#IDATALEN - 1
IDATALOOP:
CLR A
MOV @R0,A
DEC R0
MOV A,R0
JNZ IDATALOOP
; DJNZ R0,IDATALOOP
ENDIF
This piece of code sometimes stalls (seemingly at random); if I step into it with the uVision debugger, I see the DEC R0 instruction decrementing R0, then the MOV A,R0 puts the old(!) value of R0 into A.
To me that says faulty hardware. [confirm/deny]?
my IDATALEN is 80H, and i'm using a 8252.
Cheers,
Barry
  • Is this code failing in the simulator or in hardware?
    Double check that the selected register bank is bank zero.
  • Barry
    Graham's suggestion is a good one but I would like a few more details.
    Does the problem occur on the first startup or after a debugger reset?
    Are you running on a target with the debug monitor loaded?
    Are you using a version of an RTOS with your program?
    Does offsetting your initial program load change the symptoms.
    I do not feel that you have a memory problem at this time but long distance trouble shooting is worth every penny.
    Bradford
  • It doesn't seem to be exactly reproducible, although the sequence of events needed to trigger the problem may just be eluding me.
    I do have MON51 loaded, and yes; i'm using RTX51TNY (with round-robin disabled).
    Question: the keil documentation seems to say that STARTUP.A51 is the absolutely first piece of code run after a cpu reset.
    I must admit though, the problem did first occur once I started using the rtx51tiny rtos; so your suggestion as to the probable cause is likely correct :)
    cheers,
    Barry
