I have a PL/M-51 source file when I build it I get the following error *** ERROR #211, PROGRAM CODE GREATER THAN 2047 BYTES, USE ROM(LARGE) I have the memory model and the code rom size set to large. Any idea why I get this error?
Is PL/M-51 a Keil product...?
No, it's intel.
So it's off-topic, isn't it?! You need to find another forum! http://www.keil.com/forum/ http://www.keil.com/forum/terms.asp Have you tried: http://developer.intel.com
You probably set LARGE inside the Keil IDE. That only applies to C und Assembler. For PL/M-51, you have to add ROM(LARGE) on the command line. Look in the workspace for the options of your PL/M file. You will see a 'custom arguments' line at the bottom, something like '... plm51 <src.p51> OJ(...) ...' Add ROM(LARGE) to that line.
