hi I compiled an example of uvision2 .I have just changed name and I've opened new project when I've compile it,I couldnt find any hex file but I found .lst .opt .Inp. can you please inform me about this
Did you check the 'Create a Hex file box'?
the thing is I can't find any box which is called create hexor sth like that. there is an option which is called build target.isnt it enough for creating a hex file
ok ok sir i got what u mean thanks a lot.as you im student and beginner. i will try it thanks alot :)
"im student" The lesson to learn from this is: do not just jump-in blindly; take time to read the documentation! You need to read the uVision Getting Started Guide, and work through the example Projects in it. This will give you a proper introduction to the tools, how they work, and how to use them - rather than just jumping-in blindly at the deep end.
