Hi There, I have an interesting problem: In a certain memory area I am able to write to Byte 0, but when I try to write to Byte 1 the Monitor tells me "CAN NOT WRITE TO ADDRESS xxxx". Byte two is working well again, Byte three not, and so on As a result of this only every second pixel on my display has its correct color Can anybody tell me where my mistake is??
Could it be misconfigured external bus: e.g. configured as 8-bit whereas should be configured as 16-bit? Or a hardware problem: wrong connection between memory chip and MCU?
