delay time coding make me puzzled. for example: void delay() { int x=20000; do{x=x-1;}while(x>1); } how to understand it's delay.and how long time??? sincere your in advance!
Examine the assembly output and count up the instruction cycles.
Liya, How long that delay loop will take to execute depends on a great number of things. For instance, could it be interrupted and have to wait for an ISR to execute? Also, what chip are you using? What is your clock speed? Assuming that you have a "standard" 8051 type chip (like an 87C51FA for example), you should know that every assembly instruction takes 12 clock cycles to execute. So, if you were running at 16MHz, every instruction would take 750ns. So... after you write your delay function, you can look at the assembly generated and count the instructions both within the loop(for the time for each loop) and to set up the loop variables (the fixed overhead time). Then you can figure out how many loops need to execute to achieve a given delay time. Hope that helps.
every assembly instruction takes 12 clock cycles to execute. That is not correct "every assembly instruction takes a multiple of 12 clock cycles to execute" see chapter 2 of "the bible" http://www.semiconductors.philips.com/acrobat/various/80C51_FAM_PROG_GUIDE_1.pdf as to what that multiple is for the various instructions for a "standard" '51 For "unique" derivatibves such as SILabs, refer to the datasheet/user manual. ALSO delay routines should never be written in C they may cange when the compiler is revised. Erik
Erik, Good catch... Sorry if I led anyone astray. As a matter of fact, the loop presented would almost certainly generate a DJNZ which would leave someone pulling out their hair.
leave someone pulling out their hair. <.i> not me, don't have any :) Erik
Alright... given my screw up in the previous post, I thought I'd take a crack at actually creating a program with this particular delay routine in it. I made a main() function with an infinite loop that just called Delay() and then incremented another dummy variable. In my project, this generated an LCALL to Delay which would take 24 Clocks. The actual assembly produced for the function in my case was as follows:
MOV R7,#020H - 12 Clocks MOV R6,#04EH - 12 Clocks ?C0003: MOV A,R7 - 12 Clocks DEC R7 - 12 Clocks JNZ ?C0008 - 24 Clocks DEC R6 - 12 Clocks ?C0008: SETB C - 12 Clocks MOV A,R7 - 12 Clocks SUBB A,#01H - 12 Clocks MOV A,R6 - 12 Clocks XRL A,#080H - 12 Clocks SUBB A,#080H - 12 Clocks JNC ?C0003 - 24 Clocks RET - 24 Clocks
