C++ is unreplacable for the readability, ADS C++ compiler not supported by uv3, When can it be supported?
"C++ is unreplacable for the readability" Nothing contentious there, then...! :-0
Why keil does not support ADS1.2 C++ Compiler? When configed ADS1.2 compiler and compiling the C++ file in the latest uv3, the C compiler is actually called. And when we try to add file to the source group, the C++ file type is missing, does that mean that keil does not support ADS1.2 c++ compiler?
Is ADS a Keil product...?
ADS 1.2 is an outdated version. However we have added full C++ support for the current ARM product: RealView V2.2. I guess you should upgrade your old ARM toolchain to this version. Reinhard
