Porblem in including header file in Keil
I want to include header file in my project
The header file contains all the declarations. Can i use text file for the same purpose.
  • A header file (.h) is a kind of text file. It just happens to contain C syntax and has a conventional file name extension.
    Once you compile a .c, the headers on which it depends appear in uVision. You can edit the headers by double-clicking the file, as with the .c's.
