Hello, Is there a way to do symbolic debugging by download the symols only, instead of programming the flash each time a debugging session is started? Since the debugger crashes so often, it would be nice to not have to program 100k of flash each time. I'm using Keil UV2 and UV3 with Scilabs C8051F120. Thanks
