I have been work on the UPSD3354DV mcu, my application is large than 64k, so I use the bank1 and bank2 as code area. now I want to use other bank(like bank3) as data area, but when select bank3 before erase it. It do not ret from the select function. here is my code segment //pg_vm.A51 PUBLIC PG_VM_CALL,PG_VM_RET ; PG XDATA 7FE0H VM XDATA 7FE2H PG_BFR EQU 40H VM_BFR EQU 41H PG_OLD EQU 42H VM_OLD EQU 43H ; asm_PG_VM SEGMENT CODE RSEG asm_PG_VM USING 1 ;===============================================; PG_VM_CALL: PUSH ACC PUSH DPH PUSH DPL MOV DPTR,#PG MOVX A,@DPTR MOV PG_OLD,A MOV DPTR,#VM MOVX A,@DPTR MOV VM_OLD,A MOV DPTR,#VM MOV A,VM_BFR MOVX @DPTR,A MOV DPTR,#PG MOV A,PG_BFR MOVX @DPTR,A POP DPL POP DPH POP ACC RET ;===============================================; PG_VM_RET: PUSH ACC PUSH DPH PUSH DPL MOV DPTR,#VM MOV A,VM_OLD MOVX @DPTR,A MOV VM_BFR,A MOV DPTR,#PG MOV A,PG_OLD MOVX @DPTR,A MOV PG_BFR,A POP DPL POP DPH POP ACC RET ;===============================================; ; END //call pg_vm_call to select bank unsigned char idata *pPGVM = 0x40; pPGVM = 0x40; *pPGVM = 0x07; pPGVM = 0x41; *pPGVM = 0x1F; pg_vm_call(); erase_bank(0x8000); pg_vm_ret(); I trace the code. It do not ret from pg_vm_call, just step into the pg_vm_ret(); why it do not ret from pg_vm_call()??
now I want to use other bank(like bank3) as data area, That cannot work. For starters, actual data (i.e. variables) can't be in ROM at all --- only constants can, at least as far as your CPU and the tools know about it. Second, and much worse, you're pulling out the carpet from under your application's feet. If you switch to another code bank, you CPU will run code from that bank immediately --- but there is no code in your bank 3, is there?
