It's that same old question and I've read the support forums and there hasn't been a solution yet. I want to stream serial data in from a file to simulate the operation of charactors being send to the micro. I dont want to redirect the input from a COMM port or have the streams assigned in memory. Has anyone tried the SIN command on ARM? My device has 2 serial ports and if I type SIN = 'A' into the command line I get "error 34: undefined identifier". SIN0, SIN1 have the same effect? Thanks, Malcom
"Has anyone tried the SIN command on ARM?" SIN is not a command; it is the name of a VTREG - see your uVision Manual for details. You can list the available VTREGs with the DIR VTREG command - try that, and see if it reveals anything more hopeful for your ARM...
"SIN0, SIN1 have the same effect" That should be S0IN, S1IN, etc - see the uVision Manual
