Problem reading AD with upsd3354
I try to read ADC0 to 4 with a upsd3354, but the voltage at the pins P1.0 to 4 (measured with a scope) is always 3V3, and the readed value is 1023.
P1SFS0 and P1SFS1 are equal to 0x1f, to put this inputs in special + ADC.
The signals enter this pins via a serial 100kohm resistor. At the input of this resistor I have 0.9V but between the resistor and the upsd pins I read 3V3.
It looks like if the internal pull-up resistors are enabled ?
Can someone help me ?
