xdata struct WindowList{ struct Windows * thisW; struct WindowList * NextWindow; }; xdata struct WindowList temp; temp=temp.Next;//this line is generating an error.'=' incompatible operand
First of all, Next is not a member of type WindowList, I guess that you meant NextWindow because otherwise you will get a quite different error. NextWindow is a pointer to a structure, but temp is an instance of a structure. These are indeed incompatible. Perhaps you intended that temp should be a pointer to a structure of type WindowList - that will fix you main problem. If it is the case that all WindowList structures are in xdata, all your pointers can be memory type specific. Thus:
xdata struct WindowList { struct Windows xdata * thisW; struct WindowList xdata * NextWindow; }; xdata struct WindowList *temp; temp=temp->NextWindow;
