Default paths to header files when installed on drive other than C
I installed the KEIL uVision development environment on my E: drive.
When I add a source file that includes the header file c8051F020.h, it defaults to the path C:\KEIL\C51\INC\CYGNAL\C8051F020.H.
How can I change this default path to point at the E: drive?
Will changing the <c8051F020.h> to "c8051F020.h" cause it to look in the local directory for the file?
Thanks in advance for any help you can provide...
