in the example in the folder Keil\C51\EXAMPLES\FarMemory\16MB RAM on ADuC812.
FVAR (char, 0x015678) = 0x5A; i = FVAR (char, 0x015678);
FVAR (char, 0x016000) = 0x5A; i = FVAR (char, 0x016000);
The simulator allows (and requires) you to configure memory space and access permissions. See the Debug / Memory Map option in uVision.
if i want to write: <pre FVAR (char, 0x016000) = 0x5A what can i do ?
Well, did you, or didn't you set up a memory mapping that covers address 0x16000 in XRAM?
A search in the Knowledgebase helps in such situations: http://www.keil.com/support/docs/814.htm
