Hi, all, I get the following MAP infomation, it shows that _IDATA_GROUP_ occupy 50H length, how can I locate those group? thanks START STOP LENGTH ALIGN RELOC MEMORY CLASS SEGMENT NAME 000023H 000072H 000050H BYTE UNIT IDATA _IDATA_GROUP_
That'll be a job for the Linker - so see the Linker Manual. But what's wrong with it as it is...?
But what's wrong with it as it is...? There is no compile error and link error. I just want to know which function needs so many IData?
IDATA_GROUP is the overlayed idata from your programs functions. Look into the linker map at the Overlay Map and you'll see how much idata each function uses. Check the following manual page for Overlay Map. http://www.keil.com/support/man/docs/lx51/lx51_ln_mapfile.htm Jon
You can also look at the Compiler listing files - they give a summary of memory usage for each compilataion.
