Is it somehow possible to generate little-endian code using C51? We are using a 8051 variant as a controller for an ASIC with a little endian interface. I would like to be able to do something like: *((DWORD*)0x4000) = 0x12345678; And have the bytes written to the bus in "reversed" or Intel order, least significant byte first. Is this possible?
It's not a standard compiler option. I also have a project that uses an 8051 to control an ASIC with a 32-bit, little-endian interface. I wrote assembler routines that do the register access and endian inversion all at once. That is, a U32 will be passed in R4-R7. The 8051 core has only an 8-bit data bus, so your particular device has to have some means for building up a 32-bit data path from several 8-bit writes. It doesn't make any difference to the efficiency of your assembly code whether you MOV R4, R5, R6, R7, or MOV R7, R6, R5, R4 to your 32-bit interface. I also added routines to do common bit operations, as they can also be efficiently folded into the access. So, I have C prototypes along these lines:
U32 RegRead (U32* addr); // *addr U32 RegWrite (U32* addr, U32 val); // *addr = val; U32 RegAnd (U32* addr, U32 val); // val & *addr U32 RegOrEq (U32* addr, U32 val); // *addr |= val; U32 RegAndEqNot (U32* addr, U32 val); // *addr &= ~val;
Thanks a lot!
