How to trigger 74LS123?
Hi friends:
I got a serious problem with 74LS123.
74LS123 has been configured as following:
1CLR-----VCC
1A-------GND
1CEXT----100PF( one pin is conected to GND )
1REXT----120K
1B-------INPUT
1Q-------OUPUT
Input keeps changing from 1V to 3.5V repeatedly.
Why this chip can not be triggered?
Beg for you help....
  • Hi friends:
    1CLR-----VCC
    1A-------GND
    1REXT----120K
    1B-------INPUT
    1Q-------OUPUT
    Input keeps changing from 1V to 3.5V repeatedly ( 25HZ ).
  • A VERY personal opinion
    I call these devices one shot in the foot.
    I will, if needed, use 5 chips to avoid using a one shot in the foot. The one shot in the foot chips are the most noise sensitive chips you can find. The mixture of analog and digital circuitry makes for a device that acts different from all other chips of the same family.
    My opinion
  • Your circuit description does not line up with the data sheet I have for the 74ls123 -
    The capacitor is connected between pins 14 and 15, the resistor between pin 16 and VCC (pin 16). Try this configuration and it might have a better chance of working.
    How do you mean the input is changing from 1v to 3.5v??
    Why are you using a 74ls123 to generate a 100mS pulse? If you're using a micro, it is normally more than capable for generating pulses.
    Methinks a good read of the datasheet is in order.
    How does this hardware question relate to Keil's C compiler??? I suggest using a different forum.
  • Thank you for your generous helps...
    The input to pin 4 is a slowly rising since wave, what I want to do is to use 74LS123 as a interface between analogy input and MCU for producing impluse.
  • Sounds like you need a Schmitt Trigger, rather than a monostable?
    Anyhow, what has any of this got to do with Keil software tools...?
  • so sorry friends...
    I am using keil c51 to development my project and here is the only place which can appear in my mind right now...
    Thank you and have a good weekend...
