Hi there, Is there a way to have the Keil IDE output different hex and map filenames based on some conditional #if defined(x) like in conditional compilations? Thanks
No, it is not possible. You need to create different Targets in your uVision Project; you can then have a different HEX and MAP name for each Target See: http://www.keil.com/forum/docs/thread4296.asp
It's dead easy if you use commandline and .bat. I'll gladly send you an example. The stupid IDE expect you to make one file only or makje them separately. Erik
"The stupid IDE expect you to make one file only or makje them separately." Yes, that is a deficiency of the IDE - there's no facility to Build All Targets. There isn't even a (documented) way to do it from the command-line (apart from a batch file that calls uVision to build each Target in turn). I'm sure this omission has been bemoaned here before...?
(apart from a batch file that calls uVision to build each Target in turn) Maybe this is what you mean: a batch file that calls assembler, compiler, linker and oh51 to build each Target in turn. Erik
No, that wasn't what I meant (but I know that it is what you do). It is possible to start uVision with command-line arguments to make it rebuild a specified Target in a specified Project, and then exit. Thus you can write a batch file with the uVision "calls" to rebuid each Target in turn. This means that uVision manages all the dependencies, and you configure your project in the GUI rather than arcance compiler, assemlber, linker, etc, command-lines - if you prefer it that way. But it's all still a bodge because uVision is missing a "Rebuild All Targets" facility! :-(
Erik, I'm interested in receiving a batch file example of yours. Is it possible to send it to <geert dot vancompernolle at hotpop dot com>? Much thanks in advance. Geert
I'm interested in receiving a batch file example of yours. Is it possible to send it done Erik
This is cool. Maybe Keil can build a "Build All Targets" command? I do have some questions though. 1. Can I add files to only one target and not the others? 2. Is there a way to have all the targets show up on the project window so that I can just select the target and build it. Now I have to go to "Manage Componenets", then click on the target name, and the set it as the current target because the project window only shows the active target. Thanks Andy
Ok. Now I have a project with two targets and each target defines a label so that conditional compilation takes place to build two different binaries. Is there a way to put up a message of some sort at the end of a successful build to indicate which target was bulit to ensure that the I did not accidentally messed up the defined label in the target? I know I can probably run a shell script of some sort to compare the file date, but is there an easier way? Thanks Andy
Is there a way to put up a message of some sort at the end of a successful build done i my build .bat files Erik
Good Eric, Can you send your script to my hotmail email? User name is swi_n_die Thanks Andy
"1. Can I add files to only one target and not the others?" No: You Add files to the Project; however, you can set/clear the 'Include in Target Build' option for individual files and/or Groups on a per-Target basis. "2. Is there a way to have all the targets show up on the project window so that I can just select the target and build it." No. The Project window shows only the current Target - there's a drop-down on the toolbar where you choose the Target.
"...conditional compilation takes place to build two different binaries. Is there a way to put up a message of some sort at the end of a successful build to indicate which target was bulit" uVision already does this - at the end of the build, the very last message in the 'Build' output window is:
"<binary-name>" - n Error(s), m Warning(s).
