Hi, I am using Keil C51uvision IDE and doing projects in C language.Now i want to compile code written in assembly(new project in assembly only). Can i use the same IDE else How can i do it or which software i need to have for it. thanks poonam
"Now i want to compile code written in assembly" You don't Compile it - compiling is what a compiler does. You use the assembler to Assemble it. The IDE uses the filename extension to determine the type of translation required - you just add the files to your project. Sounds like you need to review the IDE Manuals.
