I want to link two PEC Channels together but after the first one has reached COUNT 00, the other channel doesn't start the transfer. Can somebody tell me exactly how do i have to set all the registers. Or is an application note available? Regards Marco
Can nobody help me? i need just a little appilication example... ;-(((
Maybe it might help if you used your real name, said which toolset you're using, and said what particular chip you're using...?
Mission impossible. PEC Channels cannot be linked as far as I know. But you may read in the Infineon documentation for the C16x/XC16x devices.
I'm using the uVision3 IDE and the MCBXC167-Net Board with XC167 Controller. Regards Marco
Hi Marco, if I understand the functionality of PEC channel link right , I wrote a simple program I tested the PEC channel link with. It simply writes some data bytes to CAPCOM6. The problem is to link the right channels with right level and priorities. I can send it to you without warranty, if you are interested.
main.c ....... INT_vSetPecSrcP(0, &PEC_Channel_0_Data) INT_vSetPecDesP(0, &CCU6_CC60SR) INT_vSetPecSrcP(1, &PEC_Channel_1_Data) INT_vSetPecDesP(1, &CCU6_CC60SR) // Set PEC Channel Link bit CL for PEC //channel 0 PECC0 |= 0x0800; PECC1 |= 0x0800; while(1) { ; } ........ int.c ........ if(PECISNC_C0IR) // end of PEC channel 0 { PECISNC_C0IR = 0; // Update of PEC channel 0 stuff IO_vTogglePin(P9_P4); printf("\nPEC0"); PECC0 = 0x5408; // load PECC0 control register PECC0 = 0x5408; // reset PEC pointer to begin of // Channel_0_Data INT_vSetPecSrcP(0,&PEC_Channel_0_Data) INT_vSetPecDesP(0, &CCU6_CC60SR) // Set PEC Channel Link bit CL for PEC // channel 0 PECC0 |= 0x0800; } if(PECISNC_C1IR) // end of PEC channel 1 { PECISNC_C1IR = 0; IO_vTogglePin(P9_P4); printf("\nPEC1"); PECC1 = 0x5408; INT_vSetPecSrcP(1,&PEC_Channel_1_Data) INT_vSetPecDesP(1, &CCU6_CC60SR) // Set PEC Channel Link bit CL for PEC // channel 1 PECC1 |= 0x0800; } .......
