Hello, I have a problem concerning the Keil MCBXC167-Board and the Easyweb-Application (Demo on the CDROM): Connection via PING or HTTP is not possible (timeout). IP and subnet mask are set correctly, there is also an ethernet link (LEDs LINK and SPEED are both on). - LED at P2.15 is continuosly on - Clock is 16 MHz (measured with oscilloscope via pin P3.15 with CLKOUT enabled) - DIP switches are default - LED ACT blinks sometimes if trying a PING from PC - Target in Keil is "On-Chip Flash" Any idea? Regards, Roland
Hello, I had until now the same Problem. I'm not proud about and I'm very new on C166er, but this cost me about 4 days of nerves. Perhaps you are familiar with the c166ers and you have checked this. After a have loaded a "untouched" easyWEB-Project I have changed only the "CONFIG_EBC" from 0 to 1. The flag "SAPEN" must set to four, because the extern adresslines must be selected by jumper SALSEL (Both on) or in RSTCFG AND the "SAPEN" (Segment Address Pins Enable) must set too. Very stupid... I hope that's not all trash what I said... but I'm very happy that's now working :-) Sorry for my long story and my bad english, but I'm happy..
