Hallo all, Is there an error in the listing file? It seems, as if the Adresscounter is wrongly increased. Here an Example:
0000000C 7001 STRB R1,[R0,#0x0] ; 197: _nop_(); 0000000E F7FF BL _nop_?T ; 00000010 FFF7 BL _nop_?T ; 198: _nop_(); 00000014 F7FF BL _nop_?T ; 00000016 FFF4 BL _nop_?T ; 216: } 0000001A BC08 POP {R3}
Yes, the CA LST file always inserts a worst 'case' scenario of the generated code. Since the location of 'nop' is not known at the compile time, theorical the BL would generate an 8-byte sequence. Note that the LA Linker/Locater generates a code listing file too. This code listing file shows the exact program code. It can be easily accessed from uVision by using the context menu in the editor. It opens the *.COD listing file at the position of the source code.
