Hello all. I'm using the phytec phyCORE-167 equipped with the infineon C167CR-LM mounted on a development board phyCORE HD200. I developped an application to send CAN messages and it is working right on debug but when I download the application on flash, it doesn't work. I think it is a wrong startup167.a66 configuration since I receive a CAN message that contains only FF (it is like a variable doesn't never change). Could anyone help me? What's the right option for External Memory in Target Options? Must I set BUSCON=1 in startup file? Thanks in advance, Max
