hi friends iam working on cygnal microcontroller i have evaluation software.actually iwant the following programme in assembly bcos for the customer requirement .actually i tried with the src directive but in cygnal src option its not activated i think probably in keil full version i may get this option , those who are having keil c kindly comiple the code and send me the equivalent assembly code thanks in advance streak
//Rev. 2.1 17
"i want the following programme in assembly bcos for the customer requirement." Hmmm... SO, you've taken on this job for which you have neither the skills (you can't write assembler) nor the tools (you only have the Eval version). This is probably not a sound way to do business!
HELLO MR neil iam not doing any business on net , but bcos of lack of tools iasked that any can convert c file to asm by using src directive using their full version of keil compiler, i think u have not checked my other messages read it carefully u will understand regards streak
If it's not business, why did you say "customer?"
"i think u have not checked my other messages read it carefully u will understand" He understands exactly what you mean, which is surprising bcos u spk sum gobbldegook like an ate yur old. If you think that anybody is going to use their very expensive Keil compiler to compile your code as a way round your not having paid for the full version then you must be living on another planet, or you are in fact as stupid as you sound.
1) I know how to do this 2) I will not tell you because of the total lack of common courtesy you show by a) using Stupid Monkey $hit instead of english and b) not using your name and c) use a totally irrelevant heading for your post and d) post 3 times. If you want help behave as if you want it Erik
