Equipment and software used: DAVE 2.1R22 (with C167CSr2.dip) Infineon Starterkit 167C (Phytec KC167CR with C167CS-LM) KEIL uVision3 Can anybody describes how DAVE can be used to set-up uVision correctly? What kind of files should be produced using DAVE, and which files should be used in uVision? Should .dpt file implement all configurations to to uVision including port configuration? So far we have only managed to setup only memory and bus configuration. Is it allowed to have startfile (ie. Start167.a66) when debugger is used?
Have you checked this application note? http://www.keil.com/appnotes/docs/apnt_182.asp Jon
Yes, we know that. (It is a part of Keil's Manual) When we open Dave's .dpt file in to the Keil we have only managed to setup only memory and bus configuration. Not example Port config. Jari
