The length of segment ?STACK
LINK MAP OF MODULE: 6H (DISPBIOS)
TYPE BASE LENGTH RELOCATION SEGMENT NAME
IDATA 005DH 0001H UNIT ?STACK
Q:How was the length of segment ?STACK calculated?
  • The length and of segment stack isn't calculated! It is defined in the STARTUP.A51, like this:
    ?STACK SEGMENT IDATA
    RSEG ?STACK
    DS 1
    By default L51 locates stack in the end of IDATA memory, and phisical size is
    RAMTOP-STACK = 0ffh( or 07fh for 51)- 005DH = 162 (or 34) bytes.
  • Thank you for your reply!
    The length of segment ?STACK is incorrect or meaningless in the link map? I don't include the startup.a51 in the project!
    In application,I only pay attention to the base of ?STACK ?
  • 1) The length of segment ?STACK is incorrect or meaningless in the link map?
    2)I don't include the startup.a51 in the project!
    3)In application,I only pay attention to the base of ?STACK ?
    1) since the linker does not know, it set the length to 1 and anyone who took the time to read the manual know that the stack size is " ?STACK to end of IRAM".
    2) fine, if you are not writing in C. If you are why the #&!! are you mucking whith things that are no business of yours.
    3) If you use the tools as intended you do not need to "pay attention to the base of ?STACK " SO, instead of using the tools as intended, you have created a mess where you have to do the work the tools are designed to do for you.
