Creating Hex File with Uvision
Hi i am currently programming 8051 using assembly language. I have installed uvision but i could not creat hex file with it. It just creates the obj file. so can any one plz tell me how to create a hex file which can be downloaded to 8051.
  • Check the "Create Hex File" checkbox on the Output tab in the target dialog in uVision.
  • Q: "can any one plz tell me how to create a hex file"
    A: "Check the 'Create Hex File' checkbox"
    Well blow me down! Who'd have thought of that one?!
    Why do they use such cryptic names...?!
  • It's not the checkbox name that makes it difficult so much as the fact that they put it on the Output tab, right under the "Create Executable" radio button.
    I tried searching for help with every box on the LX51 Locate tab, but that search function wouldn't locate a darn thing for me. Since that wasn't working, I went through every setting on the Debug tab to try to fix it, but Locate stayed broken.
    Luckily I stumbled across the right setting by accident.
  • [...] Luckily I stumbled across [...]
    Well, if that's not a perfect example backing the claim that there's no such thing as an intuitive user interface, per se, nothing is. ;-)
    The position of that switch is actually perfectly logical --- given there's a tab on that dialog called "Output", that's where this must be. And since you can't make a .hex file if you're building a library, "create .hex file" has every right to be a sub-option of "create executable file".
    So allow me to play Andrew's part here and say that if you find yourself falling into this kind of IDE trap, that's a hint it's time to work through the Tutorial once more.
  • Perhaps I also need to check the In Cheek box on the Tongue tab.
