variable placement
How Can I fix CONST space on code banks for any C51 program?
thx
  • The linker physically locates segments, so you would use the linker directives described in the linker manual ("assembler/utilities").
    Constants are located in the common area. If you're absolutely sure that another bank is always selected when you need the constant, you can relocate them.
