The electronic Help Book ("eBook") "C51.pdf" describes 8051 language extensions and 8051 derivatives. That's fine. I miss a helpful additional eBook in the Book Window of µVision V2.40, which describes the Standard-C Language (or ANSI-C Language). Perhaps likely the printed book "Kerninghan&Ritchie The C Programming Language" or so. I often use this printed book (i.e. Table with Operators, Table for printf arguments, ...). So I hope to get an advice to get/to buy this eBook? Thanks a lot Martin
I think you can download all the help files for Borland's C++ Builder for free - they include one that describes the standard 'C' language keywords.
Go to http://info.borland.com/techpubs/bcppbuilder/v5/updates/pro.html and look at B5LANG.ZIP Yes, it's C++, but it should still contain all you need.
If you want an actual ANSI C book as a PDF, you should surf over to the ANSI web site and buy the PDF edition of the ANSI/ISO C standard itself. At 18$ it's cheaper than K&R on paper, and you can integrate it in Keil's book tab alongside the others.
