I was wondering what the "best" way to set a bit in a variable declared in the bit addressable area. Originally I declared each bit as an sbit and therefore can set and clear them as follows
uint8_t bdata status ; sbit enable = staus ^ 0 ; enable = 1 ; enable = 0 ;
#define ENABLE 0x01 uint8_t bdata status ; status |= ENABLE ; status &= ~ENABLE ;
The two methods that you have given are not at all the same. Personally, I would always go for the first method as it is so much clearer. The only down-side is that the first method it is absolutly non-portable. The second method will be much more familiar to an ANSI C programmer. The compiler will generate quite different code in each case. I'd predict that the first method will cause SETB and CLR instructions to be used (quick and compact) whereas the second method will require a read, ORL or ANL, and a write.
The compiler generates the same code. It is smart.
"Personally, I would always go for the first method as it is so much clearer." (my emphasis) I agree, although the OP thinks the opposite! "The only down-side is that the first method it is absolutly non-portable." But it can (I say should) be encapsulated in a macro, so that porting is simply a matter of suitably redefining the macro. Similarly for all other compiler-specifics. "The compiler will generate quite different code in each case." Absolutely. Why would Keil bother to dream up this special syntax if it made no difference?!
"I was wondering what other people do and if there is a standard method for doing this?" The #define and masking is the conventional way when using a compiler without specific bit-addressing extensions (and for non bit-addressable data with Keil). Although you seem to have found a (the?) case where the Keil compiler is smart enough to replace a simple mask with a bit-set operation, the only way to guarantee it would be to use the bit-addressing extensions. And the current score is 2:1 that the bit-addressing is clearer! ;-)
The compiler does not generate the same code!
----- FUNCTION main (BEGIN) ----- FILE: 'main.c' 9: void main( void ) 10: { 11: enable = 1; 12: enable = 0; 00000F D200 SETB enable 13: 000011 C200 CLR enable 14: status |= ENABLE; 000013 432001 ORL status,#01H 15: status &= ~ENABLE; 000016 5320FE ANL status,#0FEH 16: } 000019 22 RET ----- FUNCTION main (END) -------
It looks like mine does. Maybe it has something to do with the way i have defined the variable.
$NOMACRO $SEGMENTED CASE MOD167 ; ; 'main.SRC' GENERATED FROM INPUT FILE 'main.c' ; COMPILER INVOKED BY: ; C:\Keil\C166\BIN\C166.EXE main.c BROWSE MOD167 DEBUG ; $MODINF (43) NAME MAIN NCODE CGROUP ?PR?MAIN SDATA DGROUP ?BD0?MAIN,SYSTEM ASSUME DPP3 : SDATA ?BD0?MAIN SECTION DATA BITADDRESSABLE 'BDATA0' status DSB 1 PUBLIC status ?BD0?MAIN ENDS EXTRN ?C_STARTUP : NEAR enable BIT status.0 PUBLIC enable REGDEF R0 - R15 ?PR?MAIN SECTION CODE WORD 'NCODE' ; line 1: #include "types.h" ; line 2: ; line 3: #define ENABLE 0x01 ; line 4: ; line 5: uint8_t bdata status ; ; line 6: ; line 7: sbit enable = status ^ 0 ; ; line 8: ; line 9: #pragma SRC ; line 10: ; line 11: void main ( void ) main PROC NEAR GLOBAL main ; FUNCTION main (BEGIN RMASK = @0x8000) ; line 12: { ; line 13: ; line 14: ; line 15: ; line 16: enable = 1 ; BSET enable ; line 17: enable = 0 ; BCLR enable ; line 18: ; line 19: status |= ENABLE ; BSET (status).0 ; line 20: status &= ~ENABLE ; BCLR (status).0 ; line 21: ; line 22: while(1) ; line 23: { ; line 24: ; line 25: } ?C0001: JMP cc_UC,?C0001 ; FUNCTION main (END RMASK = @0x8000) main ENDP ?PR?MAIN ENDS ; line 26: ; line 27: } END
"Maybe it has something to do with the way i have defined the variable." Or because you are using a C166 compiler as opposed to the (apparent) use of C51 by other posters. In fairness to everyone, your posts did not specify a product and I would hazard a guess that when none is specified, C51 is assumed.
"Or because you are using a C166 compiler as opposed to the (apparent) use of C51 by other posters." Which does, of course, beg the question: If C166 can do it, why can't (or doesn't) C51?
A: Because the C167 has a different output structure.
