I got a code, and modified it to run.. But i can't seem to get the code correct. it has to do with XDATA but i can't seem to get it right.
#include <AT898252.H> #include "lcd.c" BYTE ReadEEPROM(int addr) { char EEdata; WMCON |= 0x08; // Enable EEPROM memory space EEdata = addr; // --> how do u write here? WMCON &= 0xF7; // Disable EEPROM memory space return(EEdata); } // To write a single byte to a location in EEPROM. void WriteEEPROM(int addr, char EEdata) { WMCON |= 0x08; // Enable EEPROM memory space WMCON |= 0x10; // Enable EEPROM memory write addr = EEdata; --> how do u write here? msdelay(15); WMCON &= 0xEF; // Disable EEPROM memory write WMCON &= 0xF7; // Disable EEPROM memory space }
WMCON DATA 96h ; watchdog and memory control register EEMEN EQU 00001000b ; EEPROM access enable bit EEMWE EQU 00010000b ; EEPROM write enable bit WDTRST EQU 00000010b ; EEPROM RDY/BSY bit ADDRESS EQU 10H DATAS EQU 0AAH ; EEPROM read example. ;orl WMCON, #EEMEN ; enable EEPROM accesses ;mov dptr, #ADDRESS ; address to read ;movx a, @dptr ; read EEPROM ;xrl WMCON, #EEMEN ; disable EEPROM accesses ; EEPROM write example, utilizing fixed delay for write cycle. ; Delay is worst case (10 ms). Code for delay is not shown. ; Write is followed by verify (read and compare), but code to handle ; verification failure is not shown. orl WMCON, #EEMEN ; enable EEPROM accesses orl WMCON, #EEMWE ; enable EEPROM writes mov dptr, #ADDRESS ; address to write mov a, #DATAS ; data to write movx @dptr, a ; write EEPROM xrl WMCON, #EEMWE ; disable EEPROM writes xrl WMCON, #EEMEN ; disable EEPROM accesses
"the assembly version ... worked. but didn't manage to convert it into C." Then leave it in assembler! There is absolutely no point whatsoever in converting it to 'C' - just to break it!! It is perfectly acceptable & normal to have a project containing both 'C' and assembler modules. There is no problem calling assembler from 'C' and vice-versa - there is a whole section in the C51 manual that tells you how to do it!
// --> how do u write here? You have an address in xdata space at which you wish to read and write. A C pointer is an address. I'd use a pointer rather than an int. To turn a pointer into the thing at which it points, you "dereference" the pointer with the "*" operator: char* p; *p = myChar;
typedef volatile BYTE xdata Eeprom; BYTE ReadEEPROM(Eeprom* addr) { char EEdata; WMCON |= 0x08; // Enable EEPROM memory space EEdata = *addr; // Note the '*' WMCON &= 0xF7; // Disable EEPROM memory space return(EEdata); }
typedef volatile BYTE xdata Eeprom; #define EepromEnable 0x08 #define EepromWriteEn 0x10 // Address copied from asm example BYTE ReadEEPROM(Eeprom* addr) { BYTE eeData; WMCON |= EepromEnable; // Enable EEPROM memory space EEdata = *addr; // Note the '*' WMCON &= ~EepromEnable; // Disable EEPROM memory space return eeData; } void WriteEEPROM(Eeprom* addr, BYTE eeData) { WMCON |= (EepromEnable | EepromWriteEn); *addr = eeData; // Note the '*' msdelay(15); WMCON &= ~(EepromEnable | EepromWriteEn); }
#define EepromEnableRead WMCON |= EepromEnable #define EepromEnableWrite WMCON |= (EepromEnable | EepromWriteEn) #define EepromDisable WMCON &= ~(EepromEnable | EepromWriteEn) BYTE ReadEEPROM(Eeprom* addr) { BYTE eeData; EepromEnableRead; EEdata = *addr; // Note the '*' EepromDisable; return eeData; } void WriteEEPROM(Eeprom* addr, BYTE eeData) { EepromEnableWrite; *addr = eeData; // Note the '*' msdelay(15); EepromDisable; }
Ok. I did the adjustments as u suggested.. Seems there is no syntax error.. However I can't seem to build it.. Alot of errors while building it.. Heres the Eeprom.c
#include <AT898252.H> #ifndef BYTE #define BYTE unsigned char #endif typedef volatile BYTE xdata Eeprom; #define EepromEnable 0x08 #define EepromWriteEn 0x10 #define EepromEnableRead WMCON |= EepromEnable #define EepromEnableWrite WMCON |= (EepromEnable | EepromWriteEn) #define EepromDisable WMCON &= ~(EepromEnable | EepromWriteEn) BYTE ReadEEPROM(Eeprom* addr); void WriteEEPROM(Eeprom* addr, BYTE eeData); void msdelay(unsigned x); BYTE ReadEEPROM(Eeprom* addr) { BYTE eeData; EepromEnableRead; eeData = *addr; EepromDisable; return eeData; } void WriteEEPROM(Eeprom* addr, BYTE eeData) { EepromEnableWrite; *addr = eeData; msdelay(15); EepromDisable; } void msdelay(unsigned int x) { BYTE delval; while(x--) { delval = 123; /* Modify thisvalue to tune delay for 1mS */ while(delval--) ; } }
#include <AT898252.H> #include "eeprom.c" void main() { Eeprom* addr=0; BYTE b=0,eeData=0x3F; for(b=0;b<9;b++) { WriteEEPROM(*(addr+b),eeData); } }
Forget that question.. I've found a working version... Thanks for your help.. It really helped me alot.. here's a sample if anyone wants it..
#include <AT898252.H> #include <absacc.h> /* * Return EEPROM Byte at address 'adr' */ unsigned char ReadEEPROM (unsigned int adr) { unsigned char v; WMCON |= EEMEN_; // enable EEPROM v = XBYTE[adr]; // read value WMCON &= ~EEMEN_; // disable EEPROM return (v); } /* * Write EEPROM Byte 'val' at address 'adr' */ void WriteEEPROM (unsigned int adr, unsigned char val) { WMCON |= (EEMEN_ | EEMWE_); // enable EEPROM and set write bit XBYTE[adr] = val; // write value while ((WMCON & EERDY_) == 0); // wait until value programmed WMCON &= ~(EEMWE_ | EEMEN_); // disable EEPROM and write strobe } unsigned char v; void main (void) { v = ReadEEPROM (0x200); // read EEPROM address 0x200 WriteEEPROM (0x200, 6); // write 6 to EEPROM address 0x200 while (1); }
If you peek in absacc.h, you'll see: #define XBYTE ((unsigned char volatile xdata *) 0) This macro is handy if you like to think of memory as an array of bytes and don't want to deal with pointers.
Or just look at the _at_ keyword extension.
I thought about that -- but figured I might as well stick with generic techniques that work on any compiler. I'll happily use the extensions needed to take advantage of the architecture (bit, using, etc). But _at_ doesn't seem to me to add any real convenience over standard C features unless you're pointer-phobic. And it risks losing another thread to the complaint about how you can't use _at_ with initializers :)
"But _at_ doesn't seem to me to add any real convenience over standard C features unless you're pointer-phobic." It allows you to locate 'constant variables' in code space at known addresses without having to muck about with the linker..... "And it risks losing another thread to the complaint about how you can't use _at_ with initializers :)" .....but doesn't let you initialise them. What's the point of an uninitialised constant?
