I'm trying to generate a square frequency with C51. After playing around for some hours with the debuger I Know which line is giving me a headacke. The important lines (in bold) of the algorithm are as follows
new_timer_reload = 0xfe9b; new_timer_reload_high = new_timer_reload >>8; TR0=1; //run timer 0 divisions=38; //The high poti is chossen to be divided in 7 steps (rough tunning) //not like the low poti low_poti=0x32; high_poti=0x39; } void main() { init(); while(1) { add_high=high_poti/divisions; //According to the value in high poti (0 to 255) //gives me the value I should add to TL0 (0 to 6) add_high=add_high<<8; // times 256 new_timer_reload = 0xfe9b+low_poti+add_high; new_timer_reload_high = new_timer_reload >> 8; } } #pragma RB(1) timer0() interrupt 1 using 1 { TR0=0; //stop the timer EAL=0; //disable all interrupts frequen_1=~frequen_1; //invert the signal TL0 = new_timer_reload; //load the new values TH0 = new_timer_reload_high; TR0=1; EAL=1; }
Where is the declaration of "low_poti" .... wbr Norbert
It could be a volatile value problem or perhaps casting? In any event, you might find that the code becomes easier to understand if make use of a union such as:
typedef union { unsigned int w; struct { unsigned char high; unsigned char low; } b; } word_type;
volatile word_type new_timer_reload; ... new_timer_reload.w = (your calculation) ... TL0 = new_timer_reload.low; TH0 = new_timer_reload.high;
Using a union is quick & simple, but non-portable - as it relies upon the Compiler's internal data representation. Not necessarily bad, but you should be aware.
The definition of the variables is as follows: unsigned int low_poti,high_poti, add_high,new_timer_reload, new_timer_reload_high,new_timer_reload; intdivisions;
