Hi, I am using the linker LX51 ver3.30. I have two questions regarding the linker directive control file: 1. Whats the difference between using the linker directive ?PR?*?module_name and ?PR?module_name 2. I am using PDATA inside one of my functions:
//mod1.c void func1(void) { static PDATA BYTE var1; .... }
?PR?*?module_name specifies all segments that match these wildcard. For example: ?PR?func1?module_name ?PR?abc?module_name ... ?PR?module_name matches only with the segment that has exactly this name. Overlayable data segments of functions can be located with LX51 SEGMENTS directive. In uVision2 you can enter this under Options - LX51 Locate - User Segments. When you enter in this field: ?PD?func1?mod1 (X:0xC000) it should do the job, provided that your pdata page is in the address range X:0xC000 .. X:0xC000.
