I am using the MON-51 on my own 8051 hardware and need to set up Port A in order to use SRAM I have off chip. I need to set the alternate OE and CS functions on port A for my SRAM OE and CS pins before any downloading occurs or I cannot use the SRAM for download. Does anyone have a way of doing this? Thanks Tom
Port A? Where is that?
On the EZ-USB port A is Port 0 and it has special functions such as CE and OE for SRAM. I just need to set up that port(0/A) before a download somehow.
You should adopt the INSTALL.A51 file. Since Cypress made quite a bit of modifications to this file, the best would be that you contact Cypress to obtain their configuration and use this as starting point. Best regards Reinhard
