Each time after I end debug the variable I typed in the watch #1 window will not be restored when I start debug next time. I try changing the item -"Watchpoints & PA" in the debug tag,but it also does not work? Could any one help me? Thank you for your kindness.
Are you using a Monitor or the Simulator? I assume you use the Sim. Normally it should work what you do. You can also make your own .ini-file for debugging, and use the command WS in it to set up the watchpoints.
It is just as you say.Later Yesterday I find the "include" command.But after all, thank you very much.
