Dear All, I am a newbie Could you give me advice how to configure / initialize timer 2 in 517A so it will generate interrupt every 1 ms with 11.0592MHz crystal. I cannot see clearly in the datasheet of 517A how to configure this timer. There is no TR2 register like in T0 and T1 and no such TMOD. I try the code below in the initialization, but I got interrupt much faster (more than 10 KHz):
TH2 = 0xFC; TL2 = 0x67; T2CON &= 0xFD; T2CON |= 0x04; IP1 |= 0x20; IP0 &= ~0x20; ET2 = 1;
Take a look at the following example program: http://www.keil.com/download/docs/80c517_timer2.zip.asp Jon
ic now...the TF2 should be cleared by ISR! and there is setting for T2CON Thanks Jon!
