Assembly Code
I would like to run assembly code for the ARM7TDMI assembly using UVision2 or UVision3.
I'm trying to simulate the REMAP using the AT91M42800A chip.
How can i go about compiling assembly code using this software?
Thank You!
Mike
  • "How can i go about compiling assembly code using this software"
    You cannot compile assembly code - you need an Assembler to assemble assembly code!
    What does the uVision Manual say?
  • Hi
    I know that, but I see that the software compiles the startup.s file for the examples they Uvision gives.
    So, i figured that the software is able to compile assembly code for that chip? Does anyone know?
    Thank You!
    Mike
  • "the software compiles the startup.s"
    It does not Compile it.
    Compiling is what compilers do.
    You need an assembler to assemble an assembly source file.
    Of course, the Keil ARM toolset must include an assembler - no embedded toolset would be complete without one.
    The uVision Manual tells you how uVision distinguishes between 'C' source files and assembler source files (and, in fact, any other type of file you care to add to your project), and thus how it decides whether to use the Compiler or the Assembler (or whatever) to perform the necessary translation.
  • Hi
    I found that it has and that it needs a file called ArmAsm, at location D:\ARM\ADSV1_2\.
    i don't have this location and when i go to the Keil folder for Uvision, there is no such file.
    Does anyone know where i can get this file from?
    Thank You!
    Mike
  • I think you need to install also the GNU Compiler package (currently it appears that you work with the ARM ADS tool interface).
    The GNU toolchain is selected under:
    Project - Components, Environment and Books - Folder/Extensions. Just select "Use GNU Tools".
