Hi, i work on st10f168 and i would to know how can i compile a .c file (which contains fonctions) with manual fix adress. Because i want to load the disassembly code of it in external memory (ex : 0x200000) in order to execute it. Without offset the program begin in 0x00 and calls instructions can't be move. I try to put an offset in Options for target\Output\offset but it doesn t work??? If you get the solution, help me! Thanks Regards
http://www.keil.com/support/docs/942.htm
