I have two questions : 1. When compiling my project include files in the c51\INC directory can't be located. there is an error ("can't open file 'stdio . h" …..) but if I write the #include with the full path #include "c:\c51\inc\stdio.h" instead of #include <stdio.h> the files are located. My autoexec.bat file is : Set path = c:\c51\bin Set c51lib = c:\c51\lib Set c51inc = c:\c51\inc How do we specify include files that don't reside in the \C51\INC directory? 2. Another error that I've got is: ***FATAL ERROR 210: I/O ERROR ON INPUT FILE: EXCEPTION 0021H: PATH OR FILE NOT FOUND FILE: LIB\C51L.LIB I've checked and the c51l.lib file is in the lib directory What is the reason for this fatal error? Thanks Rafi
Set c51lib = c:\c51\lib If that's exactly what your line in autoexec.bat looks like, I would assume that's the cause of your problem: you have blanks in there which you shouldn't have. Remove the whitespace to both sides of the '=' and try again. Likewise for the other settings in this list. (And make sure this setting actually took hold: type
set | find /i "c51"
I removed the whitespace in both sides of the '=' and tried again after verifing the changes it didn't help ,do you have an idea ? Thanks Rafi
By default, the keil 8051 tools are installed in c:\keil\c51. Did you forget to include the KEIL in the path? Jon
no in my PC its in c:\c51, but i added those two lines to my makefile an it solve the problem now i get: ERROR 110 : CANNOT FIND SEGMENT SEGMENT : ?PR?.........and so what it means ? Thanks Rafi
This problem usally shows up when the user has COPIED the Keil tools from one computer to another instead of INSTALLING the Kiel tools. You did not mention the version of your tools. So look in the dialog Components, Environments, Books and set the correct environment for your copied version. Brad
i'm working with version 5.10, in code wright environment .
ERROR 110 : CANNOT FIND SEGMENT SEGMENT : ?PR?.........and so what it means ? You left out the important details (like the rest of the segment name that couldn't be found). If you really want to get answers, you should provide complete information and not cripple those of us who are able to help you. The error you have probably means that the linker couldn't find a segment that you manually specified in some way on the command line. Jon
