Hi! I'm using Flashmagic V1.87 for programming the LPC932. Programming works pretty fine until i set the 'enable watchdog' bit in the device configuration window. I have problems entering bootstrap mode (reset pulses or break condition) after activating the watchdog. Any ideas? Thanx!
I would post this one at http://www.esacademy.com/software/flashmagic/forum/list.php?f=1 I think an answer is more likely there Erik
I found that forum a few minutes ago, but thank you for telling me. You are right, it's more likely there. Cheers!
