Hi friends, Need some suggestion related to chossing which microcontroller or microprocessor to go for. My application will require 2 serial ports with memory around 2MB and a capability to communicate over internet. Please suggest me the microcontroller or microprocessor and additional hardware that i need to study also if possible the IDE or development platform that are best for such applications. thank every one....
Looks like the Infineon XC16x devices are the right choice for such a project. We offer Eval Boards (MCB-XC167) + Development Tools (PK166+ULINK) + RTOS with TCP/IP Networking Support (AR166).
You should also look at ARM-based microcontrollers. There are now lots of manufacturers making lots of ARM-based microcontrollers - including ones with multiple UARTs and on-chip ehternet (and more!) The ARM is to the 32-bit world what the 8051 is to the 8-bit world! The Infineon XC16x may be fine devices, but you're stuck to a single source...
Hi Andy Neil, Can you give more information about the avaliable evaluation boards,development tools,tutorials that are need for ARM based development. It will be ok if u just give me links i will go through them and if any doughts i will get back to you on this thread. thanks
http://www.keil.com/arm/
And, of course: http://www.arm.com
