Hi, Can I program the Intel 8051 Developemnt board using keil's uVision? Please give me steps how can I do that and generate HEX code and load into 8051? any help will be appreciated, Thanks, Ramana
"Can I program the Intel 8051 Developemnt board using keil's uVision?" You can write programs for any 8051 processor using Keil's 8051 tools - what board the processor is fitted into is irrelevant to the software development tools! "Please give me steps how can I do that and generate HEX code and load into 8051?" Standard advice: First, you need to read the uVision Getting Started guide, and work through the example projects in it. You need to read the following documents - commonly referred to as "the bible" for the 8051: http://www.semiconductors.philips.com/acrobat/various/80C51_FAM_ARCH_1.pdf http://www.semiconductors.philips.com/acrobat/various/80C51_FAM_PROG_GUIDE_1.pdf http://www.semiconductors.philips.com/acrobat/various/80C51_FAM_HARDWARE_1.pdf Are you also a newbie to 'C' programming in general? If so, you'll also need a good 'C' textbook. Here are some other introductory & reference materials: http://www.keil.com/books/8051books.asp http://www.8052.com/books.phtml http://www.8052.com/tutorial.phtml You will need to read the Manual(s) for your particular development board. You will need to read the Manuals for the C51 Compiler, A51 Assembler, etc, etc,...
