We would like to implement the I2C Slave function in LPC921. However, we can only find the sample code for the I2C master. Does anyone has implemented the I2C slave function for the LPC controller. I need your help!!! Thanks.
use the codearchitect from esacademy.com. You may have to manually remove either master or slave code since it generates code that does both Erik
