Hi everybody. I've created a new getkey (called TimedGetKey) and with C51 compiler I've generated a new .obj file. How Can I insert this new obj file in my project and replace the older getkey with the new? Thanks Tonino.
Assuming you are referring to the Keil library _getkey() either: 1) Rename your function _getkey() 2) Create a wrapper function called _getkey() that calls your function. The linker will automatically link in your _getkey() rather than the library version. Stefan
You will have to declare you function exactly to match stdio.h
